May 5th, 2024, 12:17pm
Output buffers for an LC VCO (Read 3868 times)
iVenky
Apr 30th, 2016, 10:50am
Hi! I am designing an LC VCO and would want to design output buffers for driving the output for testing. What's the general architecture for the output buffers? Can it be differential?  I have seen some architectures where they use class A amplifier but I would like to know what is used generally.
Thanks!
raja.cedt
Re: Output buffers for an LC VCO
Reply #1 - Apr 30th, 2016, 1:17pm
Diff pair with LC tuned load.
rfmagic
Reply #2 - May 25th, 2016, 2:03pm
It really depends on the operating frequency but a good choice would be a series of push-pull (inverting stage) stages. This way you make sure the signal is rail-to-rail. on the other hand you get a a square wave with high harmonic content. so unless you need a clean sine wave, I would choose the inverting stages.
It works fine for me up to 15GHz in 65nm CMOS
raja.cedt
Reply #3 - May 30th, 2016, 1:54pm
Dear rfic-
I would go with inverting stage if I have to buffer it internally like clock tree fashion, but if you have to bring it out and test-it with for a process maturity info or in case test-chip, you might be having some troubles with 50ohm. That's why Generally people tend to go cml buffer or a open drain structure. Correct me if I am wrong.
Raj.
rfmagic
Reply #4 - Jun 15th, 2016, 1:27pm
@ raja
I agree with your argument. I probably missed the point that this buffer should be used for low impedance load for testing.
Thanks for your correction
