Apr 25th, 2024, 9:26pm
Bondwire Inductance & Pad Cap Modelling (Read 2401 times)
jdp
Jun 29th, 2016, 8:33am
I want to model the Bondwire Inductance & Pad Capacitance that come to the picture when connecting Vdd, Gnd etc. from outside the IC. Presently, I am simulating my circuit (switched capacitor one) with a model as seen in attached schematic. Is this model okay to use?
Problem faced is that the internal supply rail voltages are RINGING - and decoupling capacitors are of no help as the Vdd & corresponding Gnd are oscillating in phase..!
Please suggest how to get rid of such ringing on internal supply rails.
-- jdp
Re: Bondwire Inductance & Pad Cap Modelling
Reply #1 - Jun 29th, 2016, 9:10am
raja.cedt
Reply #2 - Jun 30th, 2016, 2:19am
Hi-
1. Bond wire model you should get it from packing people, as a rule of thumb use 1nH/1mm with some seris resistance. I guess you have double bond, but please some mutual inductance also (~0.6).
2. Always do an Em sim for pad capacitance or calculate from metal cap density from foundry
3. . Add a small series resistance to the decap, Just add enough if it is more than enough decap is no more decap rather it is a resister, which will compromise supply noise.
This is the reason why always foundries makes decap std cells with non minimal length.
Best regards,
Raj.
jdp
Reply #3 - Jun 30th, 2016, 8:03am
Thanks Ken, and Raja!
Raja, one thing if you may please help me with.
I am attaching a MUTUAL INDUCTANCE model for my bondwires (as suggested by you). Can you please check if it's okay? (as I couldn't get much reference on the web regarding usage of "mind"), also if the inductor DOT SIGNs are properly placed?
-- jdp
raja.cedt
Reply #4 - Jun 30th, 2016, 3:48pm
yah--double bond always will have +ve mutual coupling. If you want to enhance your understanding,may be the following book might be a good start.
Electromagnetics for High-Speed Analog and Digital Communication Circuits
jdp
Reply #5 - Jun 30th, 2016, 7:56pm
So, in my previous schematic, I should add mutual coupling between ALL the inductors, right? Is a coupling coeff ~ 0.6 ok for all of them on average.
Also, Thanks for sharing the book...
-- jdp
Reply #6 - Jul 6th, 2016, 10:33pm
what is the package? does a package and bonding model exist?
jdp
Reply #7 - Jul 7th, 2016, 1:05am
Hi loose-electron,
Right now, I don't have any idea of what package I will use...
I just want to gauge how my designed ckt might behave in the actual environment of pads & bondwires..and put in place some precautionary measure (like using a damping resistor in series with decoupling cap to reduce ringing in the supply lines) if possible!
But, in the absence of a precise package and bonding model, is it anyway useful to design and use such damping resistors based on just an approx. model?  :-?
-- jdp
Reply #8 - Jul 8th, 2016, 11:48pm
Your internal model includes no C inside the chip, thus the extreme ringing.
Often under 100MHz you can design without the package model and survive.
Otherwise target some plausible packages for the chip and get a suitable model to start with
jdp
Reply #9 - Jul 9th, 2016, 1:50am
Thank you so much Jerry for sharing insight from your experience Smiley it is really helpful information..!
If you don't mind my naivety, can you please elaborate a little on what you mean by "...internal model includes no C inside the chip" - what Cap (and between what) are you referring to?
-- jdp
Reply #10 - Jul 17th, 2016, 9:41am
jdp wrote on Jul 9th, 2016, 1:50am:
Internal capacitance from power to ground
