May 5th, 2024, 4:07pm
Modeling Vout = Vin *{ 1-exp[-(t/alpha)^beta] } (Read 879 times)
jszair
Jul 10th, 2016, 4:02pm
I want to model a block that produces the following behavior
Since it has exp[-(t/alpha)^beta], I can't simply use an RC like behavior model.
Modeling it with an varying RC as a function of Vin of previous timestep is also tricky, any error will be blown up because of its exponential behavior.
Any suggestions?
Re: Modeling Vout = Vin *{ 1-exp[-(t/alpha)^beta] }
Reply #1 - Jul 25th, 2016, 5:45am
You can write that equation exactly in Verilog-A, if your simulator supports it.  There are also some simulators that allow you to specify expressions for dependent sources, though I'm not sure if you can use time in those expressions.
`include "disciplines.vams"
module myfilter(in, out);
  inout in, out;
  electrical in, out;
  parameter real alpha = 1;
  parameter real beta = 1;
  analog begin
    V(out) <+ V(in) * (1 - exp(-pow($abstime/alpha, beta)))
AMS_ei
Reply #2 - Jul 30th, 2016, 5:28am
There will be a ";" at the end otherwise, it will shout with compilation error.
Here is the correct ones:
analog begin
   V(out) <+ V(in) * (1 - exp(-pow($abstime/alpha, beta)));
