May 2nd, 2024, 5:54pm
10 mA constant current source (Read 4101 times)
umesh
Pune
Jul 24th, 2016, 9:06pm
Hi
I want to design constant current source of 10mA. My load will vary from 10 ohms to 5K ohms. I tried using current mirror circuit, but i am unable to achieve 10mA. Current mirror gives only 2mA constant current. Please suggest me another circuit which gives me 10mA constant current source. I have tried another circuit using op-Amp but it gives the constant current of 10mA up to 1.4k load range.
vroy_92
Leuven, Belgium
Re: 10 mA constant current source
Reply #1 - Jul 25th, 2016, 12:02am
"Current mirror gives only 2mA of current".. What is limiting your current mirror from giving more than 2mA of current?
V Roy
umesh
Pune
Reply #2 - Jul 25th, 2016, 2:21am
when i tried to increase current capacity then it fails to reflect the current at output side.
AnalogDE
Reply #3 - Jul 26th, 2016, 12:38am
Have you tried upsizing your current mirror by 5x?
umesh
Pune
Reply #4 - Jul 26th, 2016, 1:52am
No i haven't tried that...I have no idea about it. Please let me know how to  do this.
umesh
Pune
Reply #5 - Jul 26th, 2016, 2:27am
And if I do this then how to collect the x5 current ?
I want to flow  10mA current from load (10ohm to 5kohm).
Please give me brief idea how to do.
dnw
Reply #6 - Aug 29th, 2016, 2:18pm
What are your supplies?
10 to 5k seems too large of variations(0.1V to 50V?)
