Apr 27th, 2024, 12:09pm
Modeling jitter using simple VCO in Verilog-A (Read 2279 times)
ksnf3000
Sep 23rd, 2016, 3:35am
I am trying to model jitter in verilog-A using a simple vco. Please see the below code for it. I hvae written the testbench but its not good. Could you please point me where the mistake is in the testbench? Once I have compiled this, how do I run this in eldo? Thanks!
VCO module:
`include "constants.vams"
`include "disciplines.vams"
module jitter_analysis_vco(out,in);
input in;output out;electrical out,in;
parameter real Vmin=0;
parameter real Vmax=Vmin+1 from (Vmin:inf);
parameter real Fmin=1 from (0:inf);
parameter real Fmax=2*Fmin from (Fmin:inf);
parameter real ratio=1 from [1:inf);
parameter real Vlo=0,Vhi=1;
parameter real tt=0.01*ratio/Fmax from (0:inf);
parameter real jitter =0 from [0:0.25/Fmax);
parameter real ttol = 1e-6/Fmax from (0:1*ratio/Fmax);
real freq,phase,dT;
integer n,seed;
analog begin
	@(initial_step) begin
		seed=-718;
freq = (V(in)-Vmin)*(Fmax-Fmin)/(Vmax-Vmin)+Fmin;
if(freq>Fmax) freq=Fmax;
if(freq<Fmin) freq=Fmin;
//add the phase noise
freq=freq/ratio;
freq=freq/(1+dT*freq);
//phase is the integral of the freq modulo 2 pi
phase=2*`M_PI*idtmod(freq,0.0,1,-0.5);
//update jitter twice per second
@(cross(phase+`M_PI/2,+1,ttol) or
  cross(phase-`M_PI/2,+1,ttol)) begin
  dT = sqrt(2*ratio)*jitter*$dist_normal(seed,0,1);
  n = (phase >= -`M_PI/2) && (phase < `M_PI/2);
//generate the output
V(out) <+ transition(n ? Vhi:Vlo,0,tt);
Testbench code:
`timescale 10ns / 10ps
//`timescale 100ps / 10fs
connectrules myRules;
    connect jitter_analysis_vco input electrical, output electrical;
    endconnectrules
connectmodule jitter_analysis_vco (out, in);
   initial begin
     case(in)
         1'b0: begin v = 0;end
         1'b1: begin v = 1;end
         1'bx: begin v = 0.5; end
         1'bz: begin v = 0.5; end
     endcase
   always @in begin
     case(in)
         1'b0: begin v = 0; end
         1'b1: begin v = 1; end
         1'bz: begin v = 1;end
     endcase
   analog
     V(out) <+ transition(v, 0, 10p, 10p) + transition(r, 0, 10p, 10p)*I(out);
Thanks a lot for your help!
Re: Modeling jitter using simple VCO in Verilog-A
Reply #1 - Sep 23rd, 2016, 7:32am
How is "r" set?
ksnf3000
Reply #2 - Sep 26th, 2016, 4:38am
Please ignore the r. Please let me know how to continue with the testbench writing.
