Apr 28th, 2024, 11:57pm
layout for large capacitors (Read 2593 times)
rames
Nov 30th, 2016, 7:46am
I use tsmc18rf in 180nm technology in Cadence for make layout for my circuit. I have large capacitors in order of 10pF. I used "MIMCAP" for implementation of these large capacitors.
but they occupy large spaces in my layout. I want to use other kinds of capacitors if possible. I wanted to use poly1-poly2 capacitors to small the layout but i have no contact for poly2 to metal.
Do you know how to implement large capacitors in cadenece? is there any way to implement poly1-poly2 capacitors in cadence?
Thanks in advance
Re: layout for large capacitors
Reply #1 - Dec 8th, 2016, 10:04pm
MIMCAP structures do not have a lot of capacitance per unit area due to the thick oxide layers between metal layers. (True of many foundry processes, but all are unique)
If you can use a ground or power rail tied capacitor, that is nonlinear consider using the gate of NMOS or PMOS device.
Horror Vacui
Dresden, Germany
Reply #2 - Dec 9th, 2016, 1:50am
I would first check whether poly1-poly2 is available. Using them increase the cost of every wafer and therefore often this option is not used.
About the connection: look at the documentation of the technology. There must be anything related to it. The last chance would be to look how to connect poly2 to M1. I can image that it requires the same via as poly1.
tenso
USA
Reply #3 - Dec 14th, 2016, 11:40pm
is poly-poly more expensive than MIM even if the latter has a lower capacitance per unit area and thus covers more area?
