Jul 16th, 2024, 4:25am
a  layout question about the inductor (Read 3721 times)
baohulu
china
Aug 25th, 2017, 3:17am
hi, all
 I have seen a inductor, its layout is in the attachment.
 why the width of the inductor is narrower inside  ?  is there any benifit for this type ?
thanks
cheap_salary
Re: a  layout question about the inductor
Reply #1 - Aug 26th, 2017, 3:33am
To keep area where magnetic flux is crossed.
baohulu
china
Reply #2 - Aug 27th, 2017, 11:07pm
you say the outside has both the input and output influx, thus need large area, thus wider metal width ?
is there any paper describe this ?
thanks
cheap_salary
Reply #3 - Aug 28th, 2017, 1:27am
baohulu wrote on Aug 27th, 2017, 11:07pm:
What do you mean by input and output influx ?
Describe using correct terminologies.
baohulu
china
Reply #4 - Aug 28th, 2017, 4:10am
what does the "magnetic flux cross" means ?
if we see the screen as a plane,  the magnetic lines of flux inside the inductor has two direction, one is towards the screen, and the other is leaving the screen, you said "cross" means  both the two direction magnetic flux exist ?
cheap_salary
Reply #5 - Aug 28th, 2017, 5:31am
baohulu wrote on Aug 28th, 2017, 4:10am:
Consider simple solenoidal coil.
Expression of "magnetic flux cross" is used commonly there.
There is no input and output regarding flux.
Too easy.
Simply consider situation if inner width is not narrow with keeping outer diameter.
baohulu
china
Reply #6 - Aug 28th, 2017, 8:39pm
in the plane vertical to the inductor ring , the magnetic line can be described as "in" and "out" two direction , though the magnetic line is continuous all the time.
if the width of the inductor is opposite, the inside inductor ring width is wider than the outside ring width, the inductor can also hold the same area, or say, the same outer diameter, do you think the two type inductors have the same performance ?
