Apr 26th, 2024, 11:24am
S-parameter measurement simulation (Read 2940 times)
blue111
Sep 22nd, 2017, 10:46am
I am having some problem with s-parameter measurement procedure
Please refer to my question at the bottom of this post.
The following plots are obtained by running s-param.cir
As far as I can see, the S-parameters look good, maximum transmission/reflection at 0dB makes sense for low pass filter.
s-param.cir Retrieved from http://ngspice.sourceforge.net/docs/ngspice-27-manual.pdf#page=364
Test for Scattering Parameters
** Two ports
** Examples: Bipolar,  Tschebyschef, RC
.param Rbase=50 Vbias_in=0 Vbias_out=0
*** The two-port circuit:
** port 1: in 0
** port 2: out 0
** Bias on both ports through resistor Rbase (to obtain operating point)
** Example RF Bipolar mrf5711
** VCE 1 V, IE = 5mA
** QXXXXXXX nc nb ne
** model obtained from
** http://141.69.160.32/~krausg/Spice_Model_CD/Vendor%20List/Motorola/Spice/RFBJT/
*.include MRF5711.lib
*XMRF5711 out in e  MRF5711
*Ie e 0 5m
*Ce e 0 1
** Example Tschebyschef Low Pass filter
C1 in 0 33.2p
L1 in 2 99.2n
C2 2 0 57.2p
L2 2 out 99.2n
C3 out 0 33.2p
** Example RC
** see
** http://www.allenhollister.com/allen/files/scatteringparameters.pdf
*R2 in out 10
*C1 out int5 30p
*R1 int5 0 10
*** End of circuit
** The following subcircuit to be changed only by an experienced user!
*** Driver and readout
X1 in out S22 S12 S_PARAM
.SUBCKT S_PARAM 22 66 5 7
* Resistors emulate switches with Ron=0.001 and Roff=1e12
* to switch driver to input and readout to output (and vice versa, see below)
RS1 22 2 0.001
RS2 66 6 0.001
RS3 22 6 1e12
RS4 66 2 1e12
*Driver
Vacdc 1 0 DC 'Vbias_in' AC 1 $ ac voltage and dc bias at input (applied through load resistor)
R1 1 2 'Rbase'
E1 3 0 2 0 2       $ amplify in port ac voltage by 2
Vac 3 4 DC 0 AC 1  $ subtract driving ac voltage
R_loop 4 5 0.001
R3 5 0 1           $ ground return for measure node 5
*Readout
E2 7 0 6 0 2       $ amplify out port ac voltage by 2
R4 6 8 'Rbase'     $ load resistor at output (ac)
Vdc 8 0 DC 'Vbias_out' AC 0 $ dc bias at output (applied through load resistor)
.ends
** Check the two ac lines below for being equal!
.control
set noaskquit
set filetype=ascii
*** measurement for s11 and s21
op
** save bias voltages to vector
let Vdcnew=V(X1.1) $ former Vacdc
let Vacdcnew=v(X1.8) $ former Vdc
** first ac measurement (change this line only together with following ac line)
*ac lin 20 0.1G 2G $ use for bip transistor
ac lin 100 2.5MEG 250MEG $ use for Tschebyschef
*ac lin 101 1k 10G $ use for RC
** switch input and output
alter R.X1.RS1=1e12
alter R.X1.RS2=1e12
alter R.X1.RS3=0.001
alter R.X1.RS4=0.001
** switch bias voltages between in and out
alter V.X1.Vacdc DC=op1.Vacdcnew
alter V.X1.Vdc DC=op1.Vdcnew
*** measurement for s12 and s22
op
** second ac measurement (change this line only together with ac line above)
*ac lin 101 1 10G $ use for RC
let s11=ac1.s22
let s21=ac1.s12
settype s-param S11 S21 S22 S12
let S11db = db(s11)
let S12db = db(s12)
let S21db = db(s21)
let S22db = db(s22)
settype decibel S11db S21db S22db S12db
let P11=180*ph(s11)/pi
let P21=180*ph(s21)/pi
let P22=180*ph(S22)/pi
let P12=180*ph(S12)/pi
settype phase P11 P21 P22 P12
let Rbase=@R.X1.R4[Resistance]
settype impedance Rbase
*plot s11db s21db S22db S12db ylimit -50 0 xlog $ used with RC
plot s11db s21db S22db S12db ylimit -0.5 0 $ used with Tschebyschef
plot P11 P21 P22 P12
plot smithgrid S11 S12
*wrdata s3046 mag(S11) P11 mag(S21) P21 mag(S22) P22 mag(S12) P12 $ write simple table
wrs2p s3046.s2p $ write touchstone vers. 1 file s3046.s2p
.endc
.end
Quote:
R1 1 2 'Rbase'
this 50 ohm Rbase is connected to the netlabel 2 in the screenshot below.
Or did I misread the s-param.cir netlist ?
blue111
Re: S-parameter measurement simulation
Reply #1 - Sep 25th, 2017, 3:25am
I am stucked at visualizing E1 which purpose is to amplify in port ac voltage by 2
Any idea ?
RS1 22 2 0.001
RS2 66 6 0.001
RS3 22 6 1e12
RS4 66 2 1e12
*Driver
R1 1 2 'Rbase'
R_loop 4 5 0.001
*Readout
.ends
blue111
Reply #2 - Oct 10th, 2017, 3:17am
This line means multiply the node voltage at #2 by a factor of two and the resultant voltage appears at node #3
I do not understand this line though. Anyone ?
blue111
Reply #3 - Feb 6th, 2018, 7:27am
Quote:
By implementing the 2-volt generator as two 1-volt generators—VG1A and VG1B in series with the generator resistance RG1 as shown—we achieve the particularly simple result that the voltage at node 11 is the reflected or scattered wave b1. Since a1 equals one, this is S11 itself
I do not understand the above statement.
Why must RG1 be between S11 and VG1A ?
