Apr 26th, 2024, 2:15pm
Sigma Delta Modulator SNDR with Monte-Carlo Simulation in Cadence (Read 1580 times)
MehdiOranji
Nov 13th, 2017, 8:40pm
I want to simulate a continuous time sigma delta modulator SNDR with Monte-Carlo simulation in Cadence and see the histogram of the SNDR so as to figure out how the device mismatches impact the modulator performance. I have the output bit stream of the modulator quantizer, I have no idea how to fed the output to the monte-carlo simulation and end-up with the histogram showing "#counts vs. SNDR". I would appreciate it if someone let me know how to do that.
Mehdi
Re: Sigma Delta Modulator SNDR with Monte-Carlo Simulation in Cadence
Reply #1 - Nov 14th, 2017, 10:49am
Mehdi,
Steps
1) Setup your test bench to run the Delta-Sigma SNDR simulation
2) Use the ViVA measurements: SINAD
3) Save the SINAD results to the ADE outputs
4) Run Monte Carlo, in Explorer or Assembler
5) Plot the Histogram when done
6) Use Contribution Analysis to analyze mismatch
   See my blogs on the Cadence Community site
The output of the Delta-Sigma modulator is a PWM signal, you
can perform an FFT on it and get spectrum.
MehdiOranji
Reply #2 - Nov 14th, 2017, 11:16am
Thanks Sheldon for your kindly response. The problem is that I am using Cadence 5.10.41 which does not have the viva calculator and the explorer. Do you have any idea how I can do the job in Cadence 5.
Reply #3 - Nov 14th, 2017, 5:25pm
Mehdi,
    The calculator has a dft and can be used to create a spectrum.
You will need to write a Skill function to calculate the SNDR.
MehdiOranji
Reply #4 - Nov 14th, 2017, 5:48pm
I have no idea about the SKILL function. Where should I write the function and load and How I can use its output. Even If you have a sample program, I would appreciate it.
Mehdi
polyam
Reply #5 - Nov 20th, 2017, 8:34pm
Hi Mehdi,
I have two questions for you?
1- Mismatch analysis of what block you are interested in?
2- Are you going to do an MC analysis for a fully transistor level delta sigma?
tnx
MehdiOranji wrote on Nov 13th, 2017, 8:40pm:
Mehdi
