Jul 16th, 2024, 9:39am
Phase Noise Simulation of Injection Locked Oscillator (Read 171 times)
sarthak
Dec 13th, 2017, 7:27am
I am using the following setting for calculation of the phase noise using PSS and PNOiSE analysis:
PSS:
Beat Frequency = 50MHz (Same as the injection frequency)
Number of Harmonics = 100
PNOISE:
SweepType = relative
Relative Harmonic = 100 (Because oscillator frequency is 5G = 100*50M)
Start and Stop Frequencies = 10k and 100M
Maximum Sideband = 15
I am getting results which seem correct. Just wanted  to make sure if these parameters are correct. In particular, I am not sure if relative harmonic is the harmonic of the beat frequency or the oscillator frequency?
Thanks!
deba
Re: Phase Noise Simulation of Injection Locked Oscillator
Reply #1 - Dec 14th, 2017, 2:46am
Your settings are correct. Just make sure that maxacfreq is set to maximum_sideband times the oscillation_frequency. Otherwise the noise folding is not taken into account.
sarthak
Reply #2 - Dec 14th, 2017, 2:59am
Thank you for replying.
Should I also change the maxstep setting in the simulation?
