sarthak
I am using the following setting for calculation of the phase noise using PSS and PNOiSE analysis: PSS: Beat Frequency = 50MHz (Same as the injection frequency) Number of Harmonics = 100
PNOISE: SweepType = relative Relative Harmonic = 100 (Because oscillator frequency is 5G = 100*50M) Start and Stop Frequencies = 10k and 100M Maximum Sideband = 15
I am getting results which seem correct. Just wanted to make sure if these parameters are correct. In particular, I am not sure if relative harmonic is the harmonic of the beat frequency or the oscillator frequency? Thanks!
