Apr 25th, 2024, 11:27pm
how to override the parameter of verilog-a module with array parameter (Read 1879 times)
davidshw
China
Dec 21st, 2017, 2:35am
if a verilog-a module has an array parameter, such as
moduel test (A,B)
parameter integer p1[1:4]='{1,2,3,4} ;
analog begin
endmoudle
when instantiating this module in hspice or spectre, how to override the array parameter?
xdut  a b test  p1=???
Re: how to override the parameter of verilog-a module with array parameter
Reply #1 - Dec 21st, 2017, 7:26am
Assuming you've corrected the spelling mistakes in the VerilogA module, in spectre syntax (for spectre as the simulator) it would be:
xdut (a b) test p1=[5 6 7 8]
