Sep 20th, 2026, 4:11pm
Simulation of voltage doubler (Read 3499 times)
rhonny90
Jan 04th, 2018, 12:06pm
I want to design a voltage doubler(Using Dickson charge pump with 2 clocks) with
input voltage=Vdd=3.3V
output voltage=approximately =>6 volts
Frequency=1MHz
capacitance=5pF
I took period of clock as 2 us and width as 1 us.(zero value=3.3V and one calue=0 v)
I want the Mosfet's in saturation but they are either in region 0 or 3.Please help me out in working this circuit.
kumar.g
Frankfurt, Germany
Re: Simulation of voltage doubler
Reply #1 - Jan 5th, 2018, 1:35am
Please be more specific. Which MOSFETs are you referring to?
View Profile kumar.g write2rammy   IP Logged
rhonny90
Reply #2 - Jan 5th, 2018, 2:25am
all of them are not in saturation
Jacki
Reply #3 - Mar 26th, 2018, 4:47am
Why do you want your transistors in saturation region (2)? In a charge pump, the transistors are only switches, they should be either on or off.
