May 2nd, 2024, 4:09pm
Fully differential amplifier (Read 2128 times)
Abhishek D
Jan 17th, 2018, 7:00am
I'm a final year B.Tech student. I'm need for the design of a two stage fully differential amplifier. Can somebody help in the design steps?
I've also attached the schematic for reference.
Thanks in advance  :)
Tako
Re: Fully differential amplifier
Reply #1 - Jan 23rd, 2018, 5:24am
Hi!
Sorry for late reply.
If you have the schematic, please tell what the problem is? Why you do not simulate?
Reply #2 - Jan 23rd, 2018, 1:35pm
You don't have a common mode feedback loop
Clark
UK
Reply #3 - Jan 30th, 2018, 9:42am
Hi Abhishek,
I am assuming you have picked up this two stage diff amp schematic from some Analog Design book, and now you need help on how to size each and every transistor ? Possibly, you would also like to know which simulations to perform and how to perform them.
Before proceeding with design steps and understanding how to size each and every transistor you need to know specifications for your two stage diff amp. To name a few, differential gain, common mode gain, output swing, unity gain bandwidth, PSRR, slew rate , current consumption/power requirement. Having these specifications help you in sizing each transistor. Also, I strongly recommend, you have a clear understanding of which transistor influences which specification of your diff amp.
For instance, you differential gain is dependent on gm of your input differential pair etc.
If you have your specifications then mention them, or we can assume some arbitrary (yet realistic) specification for your diff amp and then proceed.
Also, I don't know for which type of simulation you have setup your testbench but I can see that you have AC component at only negative input. You need to have that at both the inputs for an AC simulation to measure gain (what most people look for when designing an amplifier).
-Clark.
