Apr 25th, 2024, 7:44pm
Spectrum analyzer spurs measurement (Read 1853 times)
iVenky
Feb 27th, 2018, 11:56pm
I have a question regarding spectrum analyzer spur measurement. If I want to know the spurs with respect to carrier power level, should I use the phase noise feature of the spectrum analyzer or find the dBc value directly on the spectrum (which may include AM noise also). I see different results using both ways. Which is correct? I am more interested in Period Jitter due to spurs.
deba
Re: Spectrum analyzer spurs measurement
Reply #1 - Feb 28th, 2018, 8:44pm
Phase noise analyzer is equivalent to limiting the input with a limiter and then seeing the voltage spectrum. If one use a voltage limiter(which will limit the AM noise), spectrum analyzer output and phase noise analyzer will be identical.
As you have mentioned, with spectrum analyzer there will be AM noise but with a voltage limiter the AM noise will be suppressed.
