May 1st, 2024, 12:23pm
Fully Differential Amplifier MISMATCH analysis (Read 2881 times)
Ankit
Apr 17th, 2018, 2:56am
I am designing two stage fully differential amplifier. Both stage are CMFB compensated. My problem is that after first stage only there is so much offset in output of first stage (because of mismatch) Second stage ouputs are going to vdd and ground.
Is there any solution to it.
Please find the ckt image attached.
Waiting for reply urgently.
Amit
« Last Edit: Apr 17th, 2018, 6:49am by Ankit »
kumar.g
Frankfurt, Germany
Re: Fully Differential Amplifier MISMATCH analysis
Reply #1 - Apr 23rd, 2018, 7:54am
What is the gain of this cascaded amplifier? It could be that the gain is large enough to cause the output to rail. Since you have two dominant poles you must be careful with the stability of this amplifier.
View Profile kumar.g write2rammy   IP Logged
kumar.g
Frankfurt, Germany
Reply #2 - Apr 23rd, 2018, 7:59am
Also the 2nd stage is not a differential amplifier. It acts as a common mode amplifier. Additionally,  since you have alternating NMOS and PMOS input stages, check if the output common mode of 1st Op-amp is enough to keep the 2nd stage input MOSFET in saturation. This may not be relevant to your question.
rajasekhar
Reply #3 - May 13th, 2018, 9:35pm
Hi-
WHat are you simulating here, i guess you are running open loop sim. Since it is a high gain amplifier, it is intended to use in close loop so kindly connect in Unity gain mode and check please!
vroy_92
Leuven, Belgium
Reply #4 - Jun 1st, 2018, 3:25am
kumar.g wrote on Apr 23rd, 2018, 7:59am:
Agreed that it is a pseudo differential stage and will have common mode gain, but by the use of the CMFB, won't the common mode be fixed to what the input to the second stage CMFB amplifier is?
V Roy
vroy_92
Leuven, Belgium
Reply #5 - Jun 1st, 2018, 3:31am
Is the input pair dominating the mismatch? Then its easy to fix (blow up area of the transistor/increase the gain).
But why is your second CMFB designed with the resistor cancellation network?
V Roy
