I am trying to create a verilog-A model consisting of many switches, one end of all of them being connected to a source, and the other end available as a pin. It is required that the switches turn on in sequence after fixed time intervals, with only one switch being on at a time. For this, I have tried something like this.
Code:module X(capout,gnd);
vsource #(<some source>) vin(out_temp,gnd);
genvar j,x;
analog begin
@(initial_step or initial_step("dc", "ac", "tran", "xf")) begin
generate i (0, 2) begin
ival[i] = 0 ;
for ( j = 0 ; j<=2 ; j = j +1 ) begin
@(timer(0,40u)) begin
V(capout[j]) <+ V(out_temp);
for (x=0; x<=2; x=x+1) begin
if (x!=j) begin
ival[x] = 0;
generate i (0,2) begin
I(capout[i]) <+ ival[i];
On running this, however, I get the following error.
Error found by spectre during AHDL read-in.
ERROR (VACOMP-2157): "../veriloga.va", line 24: Encountered a contribution statement embedded in an analog event. Remove the contribution statement from the analog eventIt seems that the simulator isn't able to assign the voltage to 'capout[j]' for time steps other than the ones when the timer event occurs. In those times, it is required to float the pin. It is for this very purpose that I have assigned the current function a zero value for all other pins.
Is there any way out to resolve this issue?
