Oct 12th, 2026, 2:15pm
rc synthesize problem (Read 1627 times)
liletian
MD
Aug 23rd, 2018, 10:08am
Hi all
I am trying to test the buf key word in verilog.
The following code had been wrote. It supposed to add buffers between the input signal and output signal.
However, after the synthesize, it generates the following netlist.
What is the problem here? How to use verilog key word?
Thank you
The synthesize command are
set_attribute hdl_max_memory_address_range 100000000
read_hdl -v2001 test.v
set_attribute library sage-x_tsmc_cl018g_rvt_tt_1p8v_25c.lib
elaborate
synthesize -to_generic
synthesize -to_mapped
write_hdl -generic test > test_syn.v
write_hdl -mapped test > test_synth_map.v
// Generated by Cadence Encounter(R) RTL Compiler RC14.22 - v14.20-s016_1
// Verification Directory fv/test
module test(in, en, out1, out2);
 input in, en;
 output out1, out2;
 wire in, en;
 wire out1, out2;
module test(in,en,out1,out2);
  input in,en;
  wire          in,en;
  output out1,out2;
  wire   out1,out2;
  bufif0(in,out1,en);
  buf(in,out2);
endmodule // buf
