Apr 26th, 2024, 4:12am
Maximum metal length and single connection routing in Layout XL (Read 775 times)
frasheed
Aug 25th, 2018, 4:38pm
In our process technology we have only 2 metal layers. The first metal layer can be used for the whole routing process but the second metal layer can be used to make a jumper over metal layer 1 (in case of crossover) by using Via1 . Is there any constraint that I can set define the maximum length for the second metal layer or define it as jumper ?. I am using Cadence Virtuoso XL 6.1.7.
Additionally, is there any way I can route individual connection (not net). Suppose that I have a net1 in my design which is connected to 3 pins of the components in my design. Is there any way that first I route the component 1 and component 3 pin and then from this routing path to component 2 pin ?. As far as I know auto-routing feature uses minimum spanning tree which route the complete net at once. Is there any workaround for what I need ?
