Jun 3rd, 2023, 2:38pm
BER measurement of CDR using Cadence (Read 1345 times)
kazkou
Mar 20th, 2019, 11:49am
HI,
I am new to Clock and data recovery, I need to design CDR from scratch.
I have some question for designing CDR.
Before we tapeout the chip, usually how to we know BER of our designed CDR? We get the BER through the simulation or we only need to get approximate value through calculation as described in "Verification of Bit-Error Rate in Bang-Bang Clock and Data Recovery Circuits" ?
How do we know the exact loop bandwidth of the CDR when doing pre-simulation(using cadence spectre/virtuoso) ?
Thank you
Re: BER measurement of CDR using Cadence
Reply #1 - Nov 29th, 2019, 12:48am
Kazkou,
  Assuming that the question is how to determine the value of the loop
bandwidth, equation #11. The values in the equation are the design values
of the blocks in the design. So in theory, you should be able to calculate
the BER from the initial design studies. The values of Kpd and H(f) should
be fixed. The value of Kvco maybe a challenge since control voltage to
frequency transfer function maybe non-linear. However, in most cases
this relationship is controlled by the VCO calibration and should effectively
be a constant also.
