Apr 25th, 2024, 11:45pm
Timer statement inside a for loop (Read 804 times)
knark
Mar 28th, 2019, 2:09am
Hello everyone,
I want to generate control signals that turn on a series of switches consecutively with a spacing of 1ps in between two consecutive signals going high.
My code :
`include "constants.vams"
`include "disciplines.vams"
module SourceResBank (p,n);
inout [1:2] p;
inout n;
electrical [1:2] p;
electrical n;
real expr [1:2];
genvar k;
analog begin
for (k=1 ; k<1+1 ; k=k+1)
begin
 @(timer(0, 1))
     expr[k] = 0;
 @(timer(1p*k,1))
     expr[k] = 1;
  V(p[k]) <+ transition(expr[k]);
 V(p[2]) <+ transition(expr[2]);
The @timer statements inside the loop operate only once as the output p[1] gets a transition from low to high but the second (and third and so on) remain low.
However, if I write the @timer statements individually for all bits without the loop, that would work fine and all bits would transition from low to high.
Is there some restriction on timer statements in loops which only allows it to be operated only once ?
knark
Re: Timer statement inside a for loop
Reply #1 - Mar 28th, 2019, 2:41am
I found out I made a silly mistake in the code. There is no restriction on timer statements in a loop.
