Oct 18th, 2024, 12:40am
Pages: 1 2
veriloga driver model (Read 5471 times)
michdundee78
Jun 22nd, 2019, 3:09am
can someone help me on writing a veriloga driver model (ron, roff, delay) please?
thx in advance
BR,
mich
Re: veriloga driver model
Reply #1 - Jun 22nd, 2019, 4:36pm
Doesn't really work like that here. You generally have to make an effort first by proposing something, and then we can help you by answering your questions.
hafiz2431
Reply #2 - Jul 25th, 2019, 3:57am
You can try the following code:
`include "constants.vams"
`include "disciplines.vams"
module drv_ideal(A, Y, vcc);
output Y;
electrical Y;
input A,vcc;
electrical A,vcc;
// INSTANCE PARAMETERS:
parameter real vhi = 0.8;
parameter real vlo = 0  ;
parameter real vth = 0.5*(vhi+vlo) ;
parameter real tr = 1p;
parameter real tf = 1p;
parameter real tdel =1p;
parameter real rpuon =35;
parameter real rpdon =35;
parameter real roff =10M;
// LOCAL VARIABLES:
real vy,rpu,rpd;
integer y;
analog begin
        y =  (V(A) > vth);
        vy = y ? vhi : vlo;
     V(Y) <+ transition( vy, tdel, tr, tf);
       rpu = transition(V(A)>vth ? rpuon : roff ,tdel, tr,tf);
       I(vcc,Y) <+ V(vcc,Y)/rpu;
       rpd = transition(V(A)<vth ? rpdon : roff ,tdel, tr,tf);
       I(Y) <+ V(Y)/rpd;
Reply #3 - Jul 25th, 2019, 5:08am
Hi, hafiz2431 -
Your code probably not doing what you intended. You need to look at the rules of value retention in Verilog-A, because you are contributing to both the potential:
and flow:
      I(Y) <+ V(Y)/rpd;
of the same branch between Y and ground. The rules say that the V contribution will be discarded because of the subsequent I contribution.
Reply #4 - Jul 25th, 2019, 4:01pm
Also you need a cross function to resolve the threshold crossings in the input voltage.
hafiz2431
Reply #5 - Jul 25th, 2019, 8:09pm
Hi Ken and Geoffrey,
Thanks for your response. I'm not very familiar with Verilog-A. I can just write some simple codes. Actually, I tried to address the issue raised by michdundee78.
As for the code, I could see the response at Y after a 'tdel' amount of delay from A. Moreover, I found pull-up and pull-down current at node Y equal to [V(vcc)-V(Y)]/rpuon and V(Y)/rpdon, respectively.  This served my purpose apparently but of course, I'd appreciate if you suggest some modifications.
Reply #6 - Jul 25th, 2019, 9:36pm
You need a cross function to resolve the threshold crossings in the input voltage.
hafiz2431
Reply #7 - Jul 29th, 2019, 3:23am
Hi Ken,
I added a cross function and it now looks like:
output Y;
electrical Y;
input A,vcc;
electrical A,vcc;
parameter real tdel =30p;
// LOCAL VARIABLES:
real vy,rpu,rpd;
integer y;
analog begin
   @ (cross(V(A) - vth, 0) )
        y =  (V(A) > vth);
        vy = y ? vhi : vlo;
       I(Y) <+ V(Y)/rpd;
I didn't notice any significant difference with/without the cross function. It's maybe a silly question but I'd appreciate if you explain how can I see the difference of the output with/without cross function.
Simulation set-up:
I used  Vs1 as a supply and Vs2=0.5*Vs1. Vs1=0.8V. So, when in=> high, a current =(0.8-0.4)/35 =11.4 mA will flow at a delay of 30 ps from Vs1 to Vs2. When in=> low, Vs2 will source 11.4 mA to ground.
Reply #8 - Jul 29th, 2019, 6:05am
In small/short simulations, you may not notice a difference. If you ask the simulator to run a very long simulation, it may decide to take much larger timesteps, and it could step over a whole cycle and not notice that it was skipped.
Reply #9 - Jul 29th, 2019, 6:06am
If you comment out this line:
does the result change at all?
Reply #10 - Jul 29th, 2019, 10:45am
As Geoffrey says, the cross function controls the time point selection, so to see the difference you would need to look at the time point placement. Geoffrey mentioned that in long simulations you can miss entire output pulses, but if you control your time steps that is unlikely to happen, and if it does a cross function won't help. Instead the cross function helps by accurately resolving the time of the crossing. Without it the time of the output transition can be off by a large amount. An artificial jitter of 10-20% of the pulse width is not uncommon.
Your use of cross has the 'start up' problem. The start-up problem results in the output being wrong at the beginning of the simulation. It only corrects itself after the first input transition. Instead, I recommend that you put the if statement outside the cross function ...
@(cross(V(A) - vth, 0))
if (V(A) > vth)
     vy = vhi;
else
     vy = vlo;
Geoffrey is also trying to call attention to another very odd aspect of this model.  You are driving the output with a voltage source and also driving it with pull up and pull down resistors. The resistors would have no effect on the output voltage, instead they only affect the current in the supply and ground.
« Last Edit: Jul 30th, 2019, 3:45pm by Ken Kundert »
Reply #11 - Jul 29th, 2019, 11:06am
For simulation efficiency, it is better to set tdel to 0 and make tr and tf as large as practical. So unless there is some reason to use a nonzero tdel or small tr and tf, you should not.
I mention this because people often try to make their models needlessly more accurate without realizing that they are paying a price in simulation speed.
hafiz2431
Reply #12 - Jul 30th, 2019, 12:51am
Thanks, Ken and Geoffrey for your valuable inputs. I appreciate that.
How do you think about the code now:
output Y;
electrical Y;
input A,vcc;
electrical A,vcc;
parameter real tr = 15p;
parameter real tf = 15p;
parameter real tdel =0;
// LOCAL VARIABLES:
real vy,rpu,rpd;
//integer y;
analog begin
        vy =  (V(A) > vth);
       // vy = y ? vhi : vlo;
      if (V(A) > vth)
           vy = vhi;
     else
           vy = vlo;
     // V(Y) <+ transition( vy, tdel, tr, tf);
       //rpu = transition(V(A)>vth ? rpuon : roff ,tdel, tr,tf);
       rpu = transition(vy ? rpuon : roff ,tdel, tr,tf);
       // rpd = transition(V(A)<vth ? rpdon : roff ,tdel, tr,tf);
       rpd = transition(!vy ? rpdon : roff ,tdel, tr,tf);
       I(Y) <+ V(Y)/rpd;
Reply #13 - Jul 30th, 2019, 6:52am
Have you tried it? How does it work?
hafiz2431
Reply #14 - Jul 30th, 2019, 9:12am
Yes, I tried to drive an extracted model of a transmission line. In=> input to the buffer, tx_pad<0> => output of the buffer driving the transmission line. The low level of the first 3 pulses are not zero but some other values. It's also due to initialization problem or else?
Pages: 1 2
