Nov 21st, 2026, 5:37pm
What is wrong with this comparator verilog-A model (Read 3350 times)
spunky
Analog Designer
USA
Aug 26th, 2019, 3:25pm
I have built a Verilog-A comparator model as shown in the attached picture.
Basically it is just a linear gain stage to process the input voltage delta and then output either high or low with delay.
I am noticing the comparator can give wrong state at output, i.e., the output stuck at low/high when the input delta is obviously positive/negative, especially when one of the input signal is chattering around another. And after that, the output will stuck.
Another thing I have noticed is changing the magnitude of its linear gain sometimes help, but not always.
I am very frustrated about it currently and need comments or suggestions on what the issue could be and how to improve my code for behavior modeling of comparators.
Thanks!
View Profile spunky   IP Logged
spunky
Analog Designer
USA
Re: What is wrong with this comparator verilog-A model
Reply #1 - Aug 26th, 2019, 3:28pm
Not sure how to attach the 2nd picture showing the simulated results.
But here it is.
Reply #2 - Aug 26th, 2019, 5:50pm
Seems like a lot of complexity for a comparator model. I recommend that you start simple, get that working, and then only add what you really need. A good starting point would be the Verilog-A comparator on the Verilog-AMS page.
Reply #3 - Aug 28th, 2019, 6:09am
Rather than two cross statements, trying to catch it as it goes one way or the other, I'd use one cross statement for timestep control:
    @(cross((V(inp, inm) - vthres/comp_gain)))
	  ; // null statement
and then have a plain if statement to set out_val and del:
    if (V(inp, inm) > vthres/comp_gain) begin
	  out_val = 1;
	  del = comp_delay_r;
    end else begin
	  out_val = 0;
	  del = comp_delay_f;
I'd have to read up on what the LRM says happens if you happen to hit the threshold exactly: is this a cross event? in which direction? And then I'd have to wonder if the simulator implemented it correctly.
Hesham
Reply #4 - Aug 30th, 2019, 9:32am
