Jul 2nd, 2025, 12:51am
Offset cancellation in switched capacitor circuit (Read 1894 times)
vm511
Jul 10th, 2019, 12:47pm
I was trying to use a capacitive reset switched capacitor amplifier so as to also have offset cancellation. However, I observe that as I keep decreasing the clock rate, the offset sampled starts increasing. It's not very clear to me how the clock rate would impact the offset sampled at the output since the cancellation in based on charge conservation. The feedback capacitors I am using are very small (50fF)
subtr
Analog Enthusiast
India
Re: Offset cancellation in switched capacitor circuit
Reply #1 - Dec 13th, 2019, 6:34am
if you can upload a circuit diagram of what you're doing it would be the best. Are you doing the below?
https://www.google.com/url?sa=i&source=images&cd=&ved=2ahUKEwiilvP367LmAhVHyDgGH...
Subtr
vm511
Reply #2 - Dec 13th, 2019, 6:44am
The issue had gotten resolved.
Thanks!
