Jul 5th, 2025, 2:22pm
Core transistor used in VCO? (Read 1519 times)
wafer_instructor
Hi, good job
USA
Aug 27th, 2019, 12:15am
We have many choices in a technology for transistors. They are seperated by maximum applied voltages. For example, in TSMC65nm transistors are characterized by "Nominal Supply Voltage" and it corresponds to Vdd. In transient operation, Peak voltage swing can reach 2 time Vdd value for RF circuşts with inductors. At this point, I think peak voltage swing must stay below "Nominal Supply Voltage" value. So, if you have high voltage swing circuit like voltage controlled oscillator (VCO), you must choose high voltage one. Nominal supply voltage is 1.2V and transient voltage reaches 1.9V. My question is that:
Can I use core transistor in a VCO with voltage swing above "Nominal Supply Voltage"?
RF core transistor or Digital Core Transistor can be used?  :)
subtr
Analog Enthusiast
India
Re: Core transistor used in VCO?
Reply #1 - Sep 13th, 2019, 6:26am
The transistor does not know anything about whether it's sitting in a VCO or not. It will break down if it sees voltages above reliability limits. But then if you re design your VCO with both PMOS and NMOS, the swing can be limited.
Subtr
