Presumably this depends on what you're simulating or measuring. If all your input frequencies are below the Nyquist rate, then it's not necessary to include the anti-aliasing filter. If you potentially have significant signal levels at frequencies above the Nyquist rate, or are trying to assess the effectiveness of your anti-aliasing filter, then yes you would...
