Jul 2nd, 2025, 7:27pm
VerilogA - White Noise and Flicker Noise (Read 1326 times)
saigoutham
Oct 24th, 2019, 5:00pm
I am going through the verilog A manual
http://www.lumerink.com/docs/VerilogA.pdf.
It says "The white_noise function is active only during small-signal noise analyses and returns 0 otherwise."
Could you please let me what are small-signal noise analyses in "Spectre" ?
What analysis should I use in "Spectre" to see that the effect of white_noise function?
Re: VerilogA - White Noise and Flicker Noise
Reply #1 - Oct 25th, 2019, 5:49am
Spectre's "noise" analysis will activate this function.
You should try running a noise analysis with a native resistor in Spectre, and then write a Verilog-A resistor and compare the results.
(Other analyses, like pnoise, will also show white_noise. But regular "noise" is the easiest to get started with.)
