Sep 17th, 2024, 1:51am
PAC Sweep type: absolute or relative? (Read 1138 times)
iVenky
Dec 23rd, 2019, 5:04pm
I would like to know the difference between PAC sweep types: Absolute & Relative. Cadence manual says it's recommended to use "relative" for autonomous systems like oscillators and "absolute" for driven systems like mixers. Can you please explain me the difference and why it is circuit dependent?
Re: PAC Sweep type: absolute or relative?
Reply #1 - Dec 23rd, 2019, 11:51pm
Relative is relative to the fundamental frequency. Absolute is relative to 0. So, if you sweep from 1Hz to 1MHz on a 1GHz oscillator and sweep type is absolute, then the noise will be measure from 1Hz to 1MHz. However, if the sweep time is relative, then it is measured from 1GHz + 1Hz to 1GHz + 1MHz.
The reason you use relative for oscillators is that you almost always want to know the noise near the carrier frequency, and the carrier frequency is not known precisely. In my example I said the oscillation frequency is 1GHz, but it is only approximately 1GHz. So you need a relative sweep, an absolute sweep is useless for oscillators.
With driven circuit, you do know the fundamental frequency precisely, so the need for relative sweeps is reduced. However, you are free to use either sweep type on driven circuits as suits your needs.
iVenky
Reply #2 - Dec 24th, 2019, 3:53pm
Got it! Thanks
