vm511
Hi, I am using Calibre for my layout and post-layout extraction. While my LVS and DRC come to be clean, and even PEX extraction happens without any errors(There's a warning that ideal xcell use gate-level extraction). However in the calibre view, I can see transistors that I've not instantiated- they are basically to the power rails(near the guard rings). They don't create a problem in this block. However, now I instantiate this block in another layout(this layout also has BJTs), and while PEX doesn't show any errors or warnings, on saving the calibre view it shows 69 errors - which are mostly because the transistors are shorted (drain of first to source of next and so on), and basically a single net has 2 names because of that (the drain of first mosfet and source of the next). I can just manually delete the labels, but I'm not sure if I've made some errors in my layout, which are somehow not showing up on PEX and LVS, and shows up as these 'extra transistors'? Can someone please help?
PS. I just realised there was another section for extraction issues - but cant figure out how to move the post. Apologies for the error!
