Jun 30th, 2025, 3:41pm
Cadence SFDR and ENOB simulation for DAC/ADC over frequency and input amplitude (Read 1559 times)
repah
Apr 06th, 2020, 2:36pm
I am using Cadence Spectre/Virtuoso IC5.1, so I dont have access to the new Spectrum Assistant.
I want to use Cadence Spectre/Virtuoso to plot SFDR and ENOB for a DAC (but also for an ADC later) over frequency and input amplitude.
Is there a way to do this using calculator and parametric analysis ?
Thank you.
Re:  Cadence SFDR and ENOB simulation for DAC/ADC over frequency and input amplitude
Reply #1 - Apr 10th, 2020, 2:02am
OK, well it's a bit tough if you're using a software release that came out 16 years ago and was last updated 9 years ago. The Rapid Adoption Kit I mentioned in the other post is not going to help you very much then...
If I remember rightly, the wavescan calculator had a spectrum function - but I may be mistaken as to when that was introduced. You should check the documentation.
You really should look into trying to use a software release from at least the last 5 years!
repah
Reply #2 - Apr 16th, 2020, 3:04pm
Thank you.
It's difficult to learn the fundamental concepts when the program does everything for you.  Once you know, it's good to go to the lastest software version though.
