Apr 26th, 2024, 3:44pm
INL/DNL of DAC using Monte Carlo Statistical Simulation in Cadence Spectre (Read 439 times)
repah
Apr 16th, 2020, 2:56pm
I would like to do INL/DNL of DAC using Monte Carlo Statistical Simulation in Cadence Spectre.
Is it a matter of plotting each Monte Carlo run as I would one run ?  Then grab all the data, post-process ?
I would like to do 50 runs using the PDK mismatch parameters - ie.  See the effect of device mismatch on INL and DNL.
Thank you.
