Jun 30th, 2025, 1:53pm
Conversion Rate and Data Converters (Read 854 times)
repah
Apr 25th, 2020, 3:13pm
I want to use Model Writer in Cadence Spectre to make verilog models of an ADC and DAC - 10 bit each.
My ADC has a 2ns conversion rate - I set this in the ADC block settings.  Both ADC and DAC are clocked at 1MHz.
What should I set the conversion rate of the  DAC to be and why ?
