Sep 23rd, 2026, 10:47pm
jitter measurement for phase domain model PLL (Read 3886 times)
rezarmzn
Aug 19th, 2020, 8:09am
Following your guide-line (Predicting the Phase Noise of PLL-Based Frequency Synthesizers) we have created the phase domain model for our PLL. Those models require a certain parameters (fcorner, white_noise_spd, ...) to be measured on the real circuit and be used here. the question is when running the simulation (either noise or pnoise) to measure these parameters what frequency range we should integrate it for?
e.g. we have frequency divider (VCO frequency is 16GHz, 16G / 8 = 2G) and the bandwidth of the PLL is roughly 20MHz. The input reference frequency is 2GHz. How to measure fcorner and white_noise_spd.
Re: jitter measurement for phase domain model PLL
Reply #1 - Aug 19th, 2020, 3:22pm
The divider model takes the power spectral density as a parameter, so you do not integrate the noise before applying it to the model. Just measure the strobed noise in terms of phase, split into flicker and white regions, give frequency that partitions the two regions as the corner frequency fc and give the power spectral density of the white region as n.
rezarmzn
Reply #2 - Aug 20th, 2020, 9:08am
Is there any particular function in the Cadence which can calculate corner frequency? Or should I post-process the data?
Reply #3 - Aug 20th, 2020, 9:47am
I don't know. I am not that familiar with the calculator. Conceptually the flicker noise has a -10dB/dec slope and the white noise is flat. The corner frequency is where the asymptotes for these two regions intersect.
