Jul 15th, 2024, 9:38pm
Element for producing half and one clock cycle delay in Cadence (Read 1311 times)
D-Generation X
Dresden, Germany
Feb 15th, 2022, 5:03am
Hi All,
I want to introduce a delay of half and one clock period in an analog circuit. I need an element/circuit that can produce half-clock period in real circuit to be taped out. I cannot use a D flip flop as the output needed is an amplitude varying square signal. (atch 2). Looking forward to ideas..
polyam
Re: Element for producing half and one clock cycle delay in Cadence
Reply #1 - Mar 8th, 2022, 9:28am
Perhaps you could use the clock/shifted version of that in an analog fashion, something like summing amplifier, to create different levels and to sum them. I highly doubt you could use logics to create such a function because the logic level is always gnd/VDD. Simply treat the clock as if it is an analog signal.
D-Generation X
Dresden, Germany
Reply #2 - Mar 10th, 2022, 2:21am
Sorry, I was not able to get your point. I will post a better diagram from simulink, please have a look
polyam
Reply #3 - Mar 10th, 2022, 10:34am
It is a bit difficult to open a brainstorming discussion without knowing enough details. I am assuming that you are generating such a clock, or better said a waveform, with analog circuits. Is my assumption correct? How are you going to generate such a waveform?
My initial thought is that you cannot generate that clock with logics. Can you?
I haven't given so much thought to this problem but I see your waveform as a pure analog signal with different voltage levels. One solution could be using a simple low pass filter i.e. 1/1+sTs. Playing with time constant you can make a variable delay. However, there are two issues here, first you are eliminating higher order harmonics by doing so. Also, the output of the filter has to settle fast enough in order not to have distortion. Perhaps, you could approach the problem with an all pass filter and having control on the delay of analog all pass filter but settling time is still a big of concern. I would be nice if you could give a little bit of background on this problem. The application, how you want to generate that waveform etc.
D-Generation X
Dresden, Germany
Reply #4 - Mar 11th, 2022, 2:43am
Hi Polyam,
Yes you are right, lets just call it as a analog square waveform.
So I am actually designing a compensation circuit, and this waveform is the compensation signal which is to be delayed by half clock period and added for compensation.
This waveform is exactly as shown in previous figure, it has fixed frequency, fixed period(100%) but varying amplitude. Just so not be confused with clock signal.
Its a pure analog signal with different voltage levels hence I need an analog delay here. Logic gates wont work here.
Since these voltage levels are very low , it is important that amplitude are not affected.
Meanwhile, I will check about all pass filters...
polyam
Reply #5 - Mar 11th, 2022, 6:14am
Watch this specifically 15:25
https://www.youtube.com/watch?v=R8GR8o7DEbE
and
https://www.circuitstoday.com/all-pass-filters
That's one way of implementation
D-Generation X
Dresden, Germany
Reply #6 - Mar 15th, 2022, 5:53am
I will check, thanks.
But do you think there is a way using a variation of switched capacitor circuits?
