Jan 18th, 2026, 12:08am
Workaround for using systemVerilog type #delay (Read 1962 times)
mikev
Nov 30th, 2022, 9:13am
Is there a work around for using systemVerilog type delays in veriloga-ams?
For example, in sv:
#1us
#1ms
#1ns
Is there a way to do this in vams?
Thanks in advance.
Re: Workaround for using systemVerilog type #delay
Reply #1 - Nov 30th, 2022, 11:34am
Set the time unit in the `timescale directive to 1s, then use the scale factor without the units.  For example:
`timescale 1s/1ps
always #50n out = !out;
