Nov 10th, 2026, 7:33pm
sample vs continuous phase (Read 6659 times)
tempora123
Sep 06th, 2023, 4:50am
hi,
quick question about sampled vs continuous time system phase.
when using  sampled system (here dc/dc converter) there is an additional delay td of e^-jwtd in the loop due to sampling. Therefore, my expectation (and excel's) was to have a difference in phase in Bode plots when approaching the sampling frequency. However, pss + pac shows somehow different results. Attached spectre's sim results and excel calculations.
It seems pss+pac phase results start rolling off much closer to the sampling frequency than e^-jwtd predicts.
Does anyone know why it is so?
Re: sample vs continuous phase
Reply #1 - Sep 7th, 2023, 10:46pm
e^-jwtd is the delay of an ideal delay line.  What you have is a sampled data system.  Its delay will have a sin(x)/x characteristic.
tempora123
Reply #2 - Sep 8th, 2023, 12:54am
Thank you Ken for the reply. I'll double check and come back in case of additional questions.
Best regards
tempora123
Reply #3 - Sep 11th, 2023, 8:17am
Hi Ken,
I have one additional question. Since the DC/DC power stage signal flow is from switches' gates to drains, will we still see the sinc(x) behaviour there?
I agree that the sampled nature of the signal will be seen from VDD/VSS (e.g. sources) to VOUT (drains).
I've tried simulating the power stage (high side only) as sample and hold but the input signal being at the gate of the switch, instead of source, but I get completely wrong results.
Thank you for clarifications.
Reply #4 - Sep 11th, 2023, 7:14pm
I cannot make any sense of your question.  Are you thinking the output switch is the only sampling process in a DC/DC converter.  What about the PWM?
tempora123
Reply #5 - Sep 11th, 2023, 11:16pm
hi Ken,
as a starting point I have tried a simple voltage control loop, like for example here:
https://www.researchgate.net/figure/Voltage-Mode-Controlled-Buck-dc-dc-Converter...
analysing the phase shift across different stages.
Do you suggest to look into phase shift from Vcon to switch's output rather than from PWM signal to its output?
Reply #6 - Sep 11th, 2023, 11:32pm
I am confused as to why are asking me.  Why would I have an opinion on what signals you should be looking at?
tempora123
Reply #7 - Sep 12th, 2023, 12:24am
ok, I don't see the sinc(x) behaviour at the switch stage, other blocks (LC filter and errAmp with compensation network around it) are continuous time and their H(s) are as expected.
Reply #8 - Sep 14th, 2023, 2:40am
I hope you understand that you won't see a perfect sin(x)/x as the sampling processes in a switching converter are not ideal sample & hold processes.  Instead they will have sin(x)/x characteristics.
Both the PWM and the switch & filter are blocks that exhibit both sampling and memory, and so I would expect to contribute sin(x)/x like characteristics.
The whole thing is a loop, so I would expect to see sin(x)/x characteristics pretty much everywhere.
I'm afraid you are going have to figure out what is going on on your own.  I have very limited information and so can only guide you with generalities ad I feel like I have pretty much done all I can.
I encourage you to try to understand what you are seeing.  It is my experience that SpectreRF results can be challenging to interpret, but can provide insight if you take the time to understand them.
tempora123
Reply #9 - Sep 14th, 2023, 10:17pm
Thanks for the feedback. I can see that the sinc behaviour is present due to sampling. but maybe you can clarify why it is present when input is DC? In the pic attached, let's skip Q2, VIN=DC, Q1 is clocked.
Thank you
Reply #10 - Sep 15th, 2023, 10:06am
Presumably you performed a PAC analysis to see the sin(x)/x behavior.  So your input is not DC.  It is a sinusoid swept over a wide range of frequencies.  The sampiing comes from the clock on q1.  The voltage on the capacitor will be a sampled-and-held version of the input.  It won't be a simple sin(x)/x because of the influence of inductor and imperfections in the switch.
tempora123
Reply #11 - Sep 18th, 2023, 6:58am
Thank you for the feedback, all is clear now.
tempora123
Reply #12 - Sep 24th, 2023, 2:37am
for completeness: I've updated my calculations with the sinc behaviour due to sampling. Now, the phase rolls off much closer to fs frequency as per attached pic.
