May 8th, 2024, 8:32pm
Direct Conversion mixer with small beat freq. (Read 4044 times)
R. Zakai
Dec 08th, 2003, 1:34pm
I am simulating a direct conversion mixer with LO and an RF signal that are very close in frequency. As a result, the simulator has a small beat frequency. PSS analysis simply fails to converge as long as the beat frequency is low. It converges just fine if the RF signal is taken away and only the LO signal is present.
Can anyone suggest changes in my technique or other things I can do to successfully run the simulation with both LO and RF signals present. My end goal is to estimate IIP3 which requires running PSS simulation with LO and first RF.
Raz
Frank Wiedmann
Munich, Germany
Re: Direct Conversion mixer with small beat freq.
Reply #1 - Dec 9th, 2003, 12:45am
In SpectreRF, the QPSS/QPAC analysis is the method of choice for this kind of simulation. You should select the LO as the large signal.
You can find some useful information about how to set up a QPSS analysis in Appendix F of the SpectreRF User Guide. If you have access to SourceLink, you can find it at http://sourcelink.cadence.com/docs/files/Release_Info/icoa5033/spectreRF/appF.ht....
Another suitable analysis type for simulating the IIP3 of a mixer is Harmonic Balance, if you have access to a simulation engine that offers this feature.
Reply #2 - Dec 9th, 2003, 7:50am
Frank is right. QPSS is the way to go for the base analysis, with QPAC, QPXF, and QPnoise being used for the various small signal analyses.
You will also want to take a look at Accurate and rapid measurement of IP2 and IP3 at http://www.designers-guide.com/Analysis/. It describes a way of computing IP3 that is much faster than the traditional approach. That paper describes the technique in terms of an LNA and PSS/PAC, so you will have to adjust the procedure to fit a mixer and QPSS/QPAC.
