You can use the test bench described in "A test bench for differential circuits" at
www.designers-guide.com/Analysis.
To measure the settling time of a CMFB circuit, you would place it in context, with load and all, and use the test bench to drive it with a common mode pulse, and then measure the time for it to settle to the desired degree.
