May 1st, 2024, 12:41am
Settling time for a fully differential opamp (Read 5765 times)
Count
Singapore
Dec 14th, 2003, 9:35pm
Hi, I have a fully differential folded cascode opamp using a resistor feedback CMFB. How do I measure the settling time with a 10pF load? Thanks
Re: Settling time for a fully differential opamp
Reply #1 - Dec 14th, 2003, 10:50pm
You can use the test bench described in "A test bench for differential circuits" at www.designers-guide.com/Analysis.
To measure the settling time of a CMFB circuit, you would place it in context, with load and all, and use the test bench to drive it with a common mode pulse, and then measure the time for it to settle to the desired degree.
Count
Singapore
Reply #2 - Dec 16th, 2003, 4:49pm
Thanks, I will try that out
