May 5th, 2024, 11:27am
PSRR and CMRR for fully differential op amp (Read 5662 times)
wstyeah
Jan 05th, 2004, 9:02am
Anyone have idea to setup configuration to simulate the PSRR and CMRR to a fully differential op amp?
thanks
Winson Wink
Forum Administrator
YaBB Administrator
Re: PSRR and CMRR for fully differential op amp
Reply #1 - Jan 5th, 2004, 10:55am
erikwanta
Reply #2 - Feb 11th, 2004, 6:10pm
Run spectre XF analysis and plot the following:
CMRR
db20(1/DATA("/Vic/PLUS" "xf-xf"))
PSRR-
db20(1/DATA("/Vn/PLUS" "xf-xf"))
PSRR+
db20(1/DATA("/Vp/MINUS" "xf-xf"))
Where Vic is the input common mode voltage, Vn is the negative supply, and Vp is the positive supply.
