Apr 26th, 2024, 4:02pm
how to define psin for class AB and class E PAs? (Read 4465 times)
sealion
Feb 3rd, 2004, 9:57am
pls help me how to define the psin of input and output ports when simulate class AB and class E PAs by using spectreRF, i'm a new user, thanks for your reply.
« Last Edit: Feb 06th, 2004, 10:15am by sealion »
Re: how to define psin for class AB and class E PA
Reply #1 - Feb 5th, 2004, 2:44pm
Your question is a little vague - but one thing I would
recommend is to use the "port" component rather
than "psin" - it's a more direct map to spectre's port
component, and it is considerably easier to use.
Without knowing what you're trying to measure, nobody
will be able to advise you how to set it up...
sealion
Reply #2 - Feb 15th, 2004, 12:07pm
You are right, I'm a new user, can you tell me how to define them?
Thanks a lot!
Sealion
Reply #3 - Mar 4th, 2004, 9:14am
Well, your reply was also vague, so no I can't tell you
how to define them. I still don't know what you're trying to measure.
Andrew (without his ESP headgear on)
