Jul 18th, 2024, 11:31am
Silvaco's models (Read 88 times)
August West
I'll get up and fly
away
Silvaco's models
Mar 01st, 2004, 11:56am
Has anyone taken a serious look at the Silvaco models (http://www.silvaco.com/downloads/verilogADownloads.html). If so, how do they look?
I took a careful look and the diode, and it does not seem ready for prime time. It had a couple of issues.
1. Several standard parameters are missing (eg, ibv, xti)
2. vj parameter is misnamed phi, and given wrong default value.
3. noise model is missing.
4. The current used to determine the size of the diffusion capacitance includes the current through the junction and diffusion capacitances, which it should not.
Are the other models is a similar state? If so, it would seem it indicate that Silvaco is not yet using these models as their base models.
-August
Re: Silvaco's models
Reply #1 - Jul 9th, 2004, 8:33am
August -
You are correct that most of the models are not ready for prime-time.
Many of the problems arise from the lack of certain features in Verilog-A. For example, the BSIM3 model is also lacking noise, because you can't get the derivatives for the noise equation 8/3 kT (gm+gds+gmbs) without manually computing them -- defeating the purpose of a higher-level language.  BSIM3 did seem useable for transient, though.
There is a subcommittee (of which I am the chairman) proposing extensions to Verilog-AMS to handle these features.
Another sort of problem is that found in the MOS level=3 model.  It uses a capacitance-based model, which can result in lack of charge conservation. The subcommittee is not proposing extensions to handle this, since "everyone knows" that's a bad way to write a model now.
-Geoffrey
