Jun 30th, 2025, 7:48pm
RF Probing on Aluminum pads (Read 5150 times)
Fei
May 06th, 2004, 12:45pm
I did some measurements on chip, which has aluminum pads for probing.  Probe contact was a headache for me.
Anyone has suggestions on what type of probe should be using in this case.
caduser
Re: RF Probing on Aluminum pads
Reply #1 - Aug 17th, 2004, 8:03pm
Use cascade microtech G-S-G probes.
I think the standard pitch is 100um.
MTYang
Guest
Reply #2 - Sep 20th, 2005, 6:44pm
I assumed you have used the AuBe probe for Au pad probing. Please try the W probe which developed for Al pad, respectively. You can get it from Cascade or GGB.
  IP Logged
