May 18th, 2024, 9:14am
How to make zero lammbda?? (Read 2441 times)
Ragadast
Jul 14th, 2004, 6:04am
Somebody can tell me which parameters have I to modificate to make zero lammbda in BSIM3v3 model for Spectre?
thanks
Re: How to make zero lammbda??
Reply #1 - Jul 14th, 2004, 1:34pm
Why on earth would you want to do this?
If you want ideal behaviour, it makes no sense to use a complex model such as bsim3v3.
BTW, I think the parameter is probably pclm, but without looking at the model equations I'm not certain that this is the parameter, nor if it is the only parameter.
