May 18th, 2024, 1:39pm
Background simulation of the Spectre (Read 3096 times)
wccheng
Aug 08th, 2004, 7:52pm
Dear all,
I am using the Spectre simulator to simulate the VCO. Now, I am using the Parametric Analysis function to simulate the tuning frequency range of the VCO (vary the Vctrl of the varactor). Actually, I want to simulate it in the background simulation. I have tried to run the script of the "runSimulation". It just run one times only and will not run the no. of the run I set in the Parametric Analysis.
Therefore, how could I run the Parametric Analysis in the background simulation?
wccheng
Re: Background simulation of the Spectre
Reply #1 - Aug 19th, 2004, 10:37am
Look at using the distributed simulation options in ADE.
Alternatively use the save OCEAN script from the Parametric Analysis tool, and then run the simulation as a batch simulation using OCEAN.
Probably you'll need to read the documentation to find more info on these...
