May 18th, 2024, 6:44am
ADOS2Spectre-RF (Read 2125 times)
NOISE_RF
ADOS2Spectre-RF
Sep 07th, 2004, 4:17am
Hi all !
I begin to work on the simulation of Cyclostationary noise in RF systems, precisely in quartz crystal oscillator operates at 1to 100Mhz. I possess a new tools called ADOQ-Softwear developed a round Dipolar analysis method. Using this tool it’s possible to overcome the transient time domain problems, when is capable to provide us quickely the steady state operating conditions.  :D
Hoever, the tool is limited by SPICEI (Noise (LTI) analysis, S/C device models  :-/.
I think to create an interface between ADOQ-Software and Spectre-RF, in order to exploit the advantages analysis of Cyclostationary noise cheked with Spectre-RF.
In fact, the computing operation consist to provide the steady state conditions by ADOQ-Software and Spectre-RF can provided us the Cyclostationary noise analysis.
if you think that the idea is realizable. ???
Can you guide me to realise it ?
Advance think
Cyclo_Noise_Research
Frank Wiedmann
Munich, Germany
Re: ADOS2Spectre-RF
Reply #1 - Sep 7th, 2004, 6:40am
I believe that it is not possible to provide information about the steady-state conditions to SpectreRF from an external program. However, given a correct simulation setup, I do not see any reason why an oscillator PSS analysis in SpectreRF should not converge in a reasonable amount of time. This might even be faster than the characterization of the dipole described in http://ieeexplore.ieee.org/xpl/abs_free.jsp?isNumber=27049&prod=JNL&arnumber=120...
