terryssw
Of course, post-sim is good if you can afford the time needed. The 0.5ns non-overlp time is for the most worst case, i.e. including all parasitic wire resistance, cap, etc. Also, 0.5ns non-overlap time is usully for higher speed ADC(while your case is in medium speed). In lower-speed, this time can larger and just to make sure the opamp had enough settling time is enough.
