Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
May 19
th
, 2024, 1:12am
Home
Help
Search
Login
Register
PM to admin
Design
Mixed-Signal Design
› porblem in running Dracula
Previous topic
Next topic
porblem in running Dracula (Read 5849 times)
jimmy
Nov 20
th
, 2004, 6:20pm
I got an error message when I want to debug LVS errors after running Dracula.
Can not find BOUNDARY.DAT at /tmp/iqDir/a023352/Dracula/ !
ERROR: No LAYDE.DIS in the input paths !
Please do Setup !
But I do have the LAYDE.DIS file in my running directory.
Does anyone have idea of what is the problem?
Thank you,
jimmy li
IP Logged
Re: porblem in running Dracula
Reply #1 -
Nov 21
st
, 2004, 10:17pm
Do you have KEEPDATA=YES or KEEPDATA=INQUERY in
your *DESCRIPTION block?
Are you doing Tools->Dracula Interactive->Setup->LVS?
IP Logged
Reply #2 -
Nov 22
nd
, 2004, 7:54am
Jimmy,
According my experience, if KEEPDATA=SMART, all the files storing the LVS error message are removed. So you may not run dracula interactive.
Pls set to KEEPDATA=INQUERY or KEEPDATA=YES.
Good luck!
Yawei
IP Logged
jimmy
Reply #3 -
Nov 22
nd
, 2004, 10:39am
Andrew and Yawei,
Thank you so much. Now it works after I set KEEPDATA=YES.
The default value in our prcess kit is SMART.
Thank you again,
jimmy li
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
»» Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
