May 1st, 2024, 12:12pm
how can i use matlab to simulate PN of vco? (Read 2627 times)
dandysun
Nov 23rd, 2004, 12:04am
is that to sample the voltage of vco output node
and then make fft and get the square value of FFT outcome?
thanks
Re: how can i use matlab to simulate PN of vco?
Reply #1 - Nov 25th, 2004, 9:20pm
Dandysun,
Huh? This makes no sense whatsoever.
Are you talking about measured data from the lab, or from the output of a circuit simulator? If you're talking about simulation, then clearly you'll need to use an analysis that includes noise, like SpectreRF's pnoise analysis. If that's the case, I don't see why you'd need to use matlab.
If it's measured data, you can measure it directly on a spectrum analyser, so I don't see what matlab has got to do with it.
If you want answers to a question, you need to make sure that your question makes sense.
