Jul 20th, 2024, 9:32am
Substrate Noise Analysis (Read 3442 times)
mohammad
Jan 20th, 2005, 11:07am
Does anyone know what is the best software tool for simulating substrate noise effects? Simplex used to offer SubstrateStorm and CADMOS offered SeismIC but both of them were acquired by Cadence and it seems that Cadence have integrated both in Substrate Noise Analyst. But there are only a few documentations on it and I think they have just put them together without actually connecting them to each other.
Any comments on how to simulate substrate noise at Spice level is also appreciated. I have seen several papers suggesting small lumped element networks but it seems that they work only for small circuits.
Thanks.
M.H.
jfosorio
Ex Member
Re: Substrate Noise Analysis
Reply #1 - May 13th, 2005, 1:39am
I currentrly use Substrate storm and I have evaluated SeismIC. You are alright they were "integrated" in SNA, although I dont know any big change in substratestorm that is the software I use most.
I think that they differ in the algorith they use to modelate the subtrate. When I have evaluated SeismIC in the tutorial It surpise me a lot that you only have to describe  the subsrtate doping leval, while in substratestorm you describe the a detailed substrate profile. Then the models extracted by substratestorm are more detailed (this means a large number of Rs and Cs) . I think this is the reson substratestorm is prefered by circuits with few transistors and RF applications. However I have simulated "large" circucits with thousand  of transistors  using the macro capability of SS, Basically It assumes that in a selected area the substrate below is a single node, that is almost always true for Heavly Doped substrates with enogh substrate contacts  but it should be used with care in Lighly doped substrates.
bye
  IP Logged
